[GRASS-dev] [bug #5341] (grass) v.db.select: segfault
Brad Douglas
rez at touchofmadness.com
Mon Nov 27 16:37:03 EST 2006
On Mon, 2006-11-27 at 18:53 +0100, Maciek Sieczka via RT wrote:
> mneteler wrote (Mon, Nov 27 2006 12:00:12):
> > I have just tried on my RHEL4 64bit box, works:
> For me, on Ubuntu Breezy/32bit AMD K7 and on Ubuntu Dapper/32bit Pentium M it
> segfaults.
> Guys,
> Could other please try and report? Thanks!
> > Can you please try to debug it? It's fairly easy with 'ddd',
> > see this for a graphical guide:
> I have already put the backtrace there (see above); do you mean something else?
> > We need to better understand where and how it fails (or
> > login into your machine).
> I could arrange that. Is ssh session OK? I'd only need your IP and I can set
> it up for you tommorrow about noon.
I just downloaded the test dataset (from original email) and executed
v.db.select with the parameters specified (it's MAPS_COVER, not
MAP_COVER). Everything completes fine for me and without error.
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
