[GRASS-dev] [bug #5341] (grass) v.db.select: segfault
Maciek Sieczka via RT grass-bugs at intevation.de
Tue Nov 28 06:01:39 EST 2006
rez at touchofmadness.com wrote (Mon, Nov 27 2006 22:37:23):
> I just downloaded the test dataset (from original email) and executed
> v.db.select with the parameters specified (it's MAPS_COVER, not
> MAP_COVER).
I didn't wrote it was MAP_COVER. Where did you find it?
> Everything completes fine for me and without error.
Can you sepcify the platform and GCC version?
Thanks for testing this!
Best,
Maciek
-------------------------------------------- Managed by Request Tracker
