[GRASS-dev] Re: [bug #5341] (grass) v.db.select: segfault
Brad Douglas rez at touchofmadness.com
Tue Nov 28 09:34:00 EST 2006
On Tue, 2006-11-28 at 12:01 +0100, Maciek Sieczka via RT wrote:
> rez at touchofmadness.com wrote (Mon, Nov 27 2006 22:37:23):
> > I just downloaded the test dataset (from original email) and executed
> > v.db.select with the parameters specified (it's MAPS_COVER, not
> > MAP_COVER).
> I didn't wrote it was MAP_COVER. Where did you find it?
My mistake.  I read it wrong.
> > Everything completes fine for me and without error.
> Can you sepcify the platform and GCC version?
x86_64 gcc-3.2.3 and gcc-4.1.1.
Brad Douglas <rez touchofmadness com>                    KB8UYR/6
Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
