[GRASS-dev] Re: r.neighbors modification
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Tue Nov 28 07:48:42 EST 2006
On Tuesday 28 November 2006 00:38, Hamish wrote:
> Martin Wegmann wrote:
> > > > you might combine all those flags into one option,
> > > > #%option
> > > > #% key: size
> > > > #% type: integer
> > > > #% description: compute var & avg of NxN ring
> > > > #% options: 3,5,7,9,11
> > > > #% answer: 5
> > > > #% required : no
> > > > #%END
> > > very good - implemented
> > is it possible to add a flag when all sizes shall be computed?
> > I tried a bit with || statements in the if-then part, but had no luck
> > so far.
> > any ideas?
> from the parser standpoint:
> #% multiple: yes
> then you can have e.g. a 2 cell wide ring with
> size=5,7
> [There are two options here: multiple individual sizes or combination
> sizes. The rest talks about multiple sizes within the same map as that's
> more interesting to me.]
> [Will r.mfilter do the same as the output _avg map?]
just quick test and reply:
r.covar gives:
1.000000 0.969710
0.969710 1.000000
same algorithm but with moving window shows a few differences (see jpg).
(divide by 1000 to get correlation values between -1 and 1)
Martin
> from the g.parser help page:
> NOTES
> An option can be instructed to allow multiple inputs by adding the
> following line:
> #% multiple : yes
> While this will only directly change the Usage section of the help
> screen, the option's environmental string may be easily parsed from
> within a script. For example, individual comma separated identities for
> an option named "input" can be parsed with the following Bash shell
> code:
> IFS=,
> for opt in $GIS_OPT_INPUT ; do
> ... "$opt"
> done
> I am not sure how to do the r.mapcalc part then, maybe >> append each
> mapcalc ring size rules to a file, then run r.mapcalc redirecting the
> conglomorate file to stdin,
> r.mapcalc < $TMP.rulesfile
> it would take too much to fully paste all combinations in to the script
> without some sort of dynamic rule building.
> if you want multiple individual maps, set DO_5=0, DO_7=1 in the loop
> and then test for that, e.g.:
> DO_3=0
> DO_5=0
> DO_7=0
> IFS=,
> for size in $GIS_OPT_SIZE ; do
> if [ $size -eq 3 ] ; then
> DO_3=1
> fi
> if [ $size -eq 5 ] ; then
> DO_5=1
> fi
> if [ $size -eq 7 ] ; then
> DO_7=1
> fi
> done
> (or something like that)
> Hamish
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20061128/910fc5f9/mfilter_ring_correlation.jpg
