[GRASS-dev] Re: r.neighbors modification
Hamish
hamish_nospam at yahoo.com
Mon Nov 27 18:38:42 EST 2006
Martin Wegmann wrote:
> > > you might combine all those flags into one option,
> > > #%option
> > > #% key: size
> > > #% type: integer
> > > #% description: compute var & avg of NxN ring
> > > #% options: 3,5,7,9,11
> > > #% answer: 5
> > > #% required : no
> > > #%END
> > very good - implemented
> is it possible to add a flag when all sizes shall be computed?
> I tried a bit with || statements in the if-then part, but had no luck
> so far.
> any ideas?
from the parser standpoint:
#% multiple: yes
then you can have e.g. a 2 cell wide ring with
size=5,7
[There are two options here: multiple individual sizes or combination
sizes. The rest talks about multiple sizes within the same map as that's
more interesting to me.]
[Will r.mfilter do the same as the output _avg map?]
from the g.parser help page:
NOTES
An option can be instructed to allow multiple inputs by adding the
following line:
#% multiple : yes
While this will only directly change the Usage section of the help
screen, the option's environmental string may be easily parsed from
within a script. For example, individual comma separated identities for
an option named "input" can be parsed with the following Bash shell
code:
IFS=,
for opt in $GIS_OPT_INPUT ; do
... "$opt"
done
I am not sure how to do the r.mapcalc part then, maybe >> append each
mapcalc ring size rules to a file, then run r.mapcalc redirecting the
conglomorate file to stdin,
r.mapcalc < $TMP.rulesfile
it would take too much to fully paste all combinations in to the script
without some sort of dynamic rule building.
if you want multiple individual maps, set DO_5=0, DO_7=1 in the loop
and then test for that, e.g.:
DO_3=0
DO_5=0
DO_7=0
IFS=,
for size in $GIS_OPT_SIZE ; do
if [ $size -eq 3 ] ; then
DO_3=1
fi
if [ $size -eq 5 ] ; then
DO_5=1
fi
if [ $size -eq 7 ] ; then
DO_7=1
fi
done
(or something like that)
Hamish
