[GRASS-dev] Re: r.neighbors modification
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Mon Nov 27 09:05:30 EST 2006
On Friday 24 November 2006 12:16, Martin Wegmann wrote:
> > you might combine all those flags into one option,
> > #%option
> > #% key: size
> > #% type: integer
> > #% description: compute var & avg of NxN ring
> > #% options: 3,5,7,9,11
> > #% answer: 5
> > #% required : no
> > #%END
> very good - implemented
is it possible to add a flag when all sizes shall be computed?
I tried a bit with || statements in the if-then part, but had no luck so far.
any ideas?
TIA, Martin
Type: application/x-shellscript
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20061127/31b096ff/r.bin
