[GRASS-dev] Re: [GRASS-CVS] michael: grass6/gui/tcltk/gis.m
mapcanvas.tcl, 1.52, 1.53
Hamish
hamish_nospam at yahoo.com
Tue Nov 28 20:58:36 EST 2006
> grass intevation.de wrote on 11/28/2006 12:14 AM:
> > Author: michael
> > Update of /grassrepository/grass6/gui/tcltk/gis.m
> > In directory doto:/tmp/cvs-serv16736
> > Modified Files:
> > mapcanvas.tcl
> > Log Message:
> > Added error trap for g.region failing at GUI startup. Now it exits
> > GUI with a message about g.region failing.
> > Index: mapcanvas.tcl
> > RCS file: /grassrepository/grass6/gui/tcltk/gis.m/mapcanvas.tcl,v
Markus wrote:
> Excellent, Michael.
> Now we no longer see the "parts()" error in gis.m. I have backported
> it to 6.2-CVS for 6.2.1.
This does not work for me unfortunately. (both wish 8.3 and 8.4)
I moved /usr/lib/libgdal.so out of the way to simulate breakage, then:
G63> g.region -p
g.region: error while loading shared libraries: libgdal1.3.1.so.1: cannot open shared object file: No such file or directory
G63> echo $?
127
I changed:
- if {![catch {open [concat "|g.region" "-ug" $args] r} input]} {
+ set regcmd [concat "|g.region" "-ug" $args]
+ set retval [catch {open $regcmd r} input]
+ if {! $retval } {
But catch returns 0 and the return stream ($input) is not filled
with the stderr message (it's empty).
To get it to fail nicely I need to add some more checking:
if {! $retval } {
set havedata 0
while {[gets $input line] >= 0} {
if { ! $havdata } {
set havedata 1
regexp -nocase {^([a-z]+)=(.*)$} $line trash key value
set parts($key) $value
if { ! $havedata } {
# eof check probably redundant
if { [eof $input] } {
puts "Startup error: check 'g.region -p'"
exit 1
catch {close $input}
I can get it to pass through the "missing libgdal.so" message with:
set regcmd [list exec "g.region" "-ug" $args]
set retval [catch $regcmd result]
if { $retval } {
puts "Startup error:\n $result"
exit 1
puts "result is: $result"
but when I restore libgdal it then fails with:
Failed to run command:
ERROR: region <> not found (that's from g.region main.c region=)
Hamish
