[GRASS-dev] Re: [GRASS-CVS] michael: grass6/gui/tcltk/gis.m mapcanvas.tcl, 1.52, 1.53
Michael Barton michael.barton at asu.edu
Tue Nov 28 23:22:00 EST 2006
On 11/28/06 6:58 PM, "Hamish" <hamish_nospam at yahoo.com> wrote:
> I changed:
> - if {![catch {open [concat "|g.region" "-ug" $args] r} input]} {
> + set regcmd [concat "|g.region" "-ug" $args]
> + set retval [catch {open $regcmd r} input]
> + if {! $retval } {
I think this is problematic. The original code says in essence, if g.region
does *not* fail, do the following.
Looking at the catch command, it should store any error returned in the
variable input.
Trying replacing the line in the else clause...
puts "GRASS command g.region failed. Check to see if you've install GRASS
correctly."
With...
puts $input
When I rename g.region to g.region_x, this produces the following error
message on the command line...
couldn't execute "g.region": no such file or directory
How's this?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
