[GRASS-dev] [bug #5215] (grass) r.los module crashes (Windows)
Paul Kelly via RT grass-bugs at intevation.de
Wed Nov 29 10:46:15 EST 2006
I can confirm that it crashes on Windows when higher values for max_dist are
used. E.g. in spearfish it is OK with max_dist=2500 but crashes for
max_dist=3000. I remember from looking in depth at r.los a few years ago that
the code was quite a mess and really inefficient and, well, I'd rather
re-write it than try to fix it.
Paul
-------------------------------------------- Managed by Request Tracker
