[GRASS-dev] [bug #5352] (grass) v.db.select segfault if SQL query is malformed
Markus Neteler via RT grass-bugs at intevation.de
Thu Nov 30 02:22:53 EST 2006
I can replicate that with Spearfish:
v.db.select archsites where="CAT=1"
Segmentation fault
The debugger suggests:
 #2  0xb7edbf8e in db_realloc (s=0x804f060, n=36) at alloc.c:76
which is
lib/db/dbmi_base/alloc.c:76
s = realloc (s, (unsigned int) n);
Some memory magic...
Markus
-------------------------------------------- Managed by Request Tracker
