[GRASS-dev] are we ready for a 6.2.1 release?
Thu Nov 30 02:24:14 EST 2006
Hi.
Now that the gis.m startup error message problem is (fingers crossed)
dealt with, are there any other outstanding issues holding back a 6.2.1
release? These should be critical bug fixes only.
Due to badly broken ps.map in 6.2.0 and the common hard to understand
gis.m startup error message, I'd hope for a release soon. It is now 30
days since 6.2.0 was released (and that's a nice round number).
see
 http://grass.gdf-hannover.de/wiki/GRASS_6.2_Feature_Plan#6.2.1
* For NVIZ bug #4725 I have added a warning message with suggested
work-around so don't consider that release critical (it may take some
time to fix this one).
* I don't know anything about the r.distance NULL bugfix, do can't
comment on that.
Markus: can you trigger an new 6.2-releasebranch snapshot for testing?
Hamish
ps - any cvs2cl.pl hints?
Do you need to do a full checkout of the 6.2 branch to run it?
Are the following requests->commands correct?
doc/howto_release.txt:
     #create ChangeLog on release branch:
     sh tools/cvs2cl.pl --follow "$CVSBRANCH"
6.2.newbranch->6.2.latest
    -F *BRANCH*, --follow *BRANCH*
        Show only revisions on or ancestral to *BRANCH*.
or
6.2.a -> 6.2.b
    --delta *FROM_TAG*:*TO_TAG*
        Attempt a delta between two tags (since *FROM_TAG* up to and
        including *TO_TAG*). The algorithm is a simple date-based one
        (this is a hard problem) so results are imperfect.
