[GRASS-dev] [bug #5175] (grass) v.to.db: 'option=cat' not
updating columns other than 'cat'
Hamish
hamish_nospam at yahoo.com
Sun Oct 1 02:34:37 EDT 2006
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=5175
> Subject: v.to.db: 'option=cat' not updating columns other than 'cat'
> Even if I specify a valid integer output 'column' for 'option=cat':
> v.to.db -s map=huha2 type=point layer=2 option=cat column=gimme
> v.to.db ignores it and updates the column "cat" instead:
> Updating database ...
> insert into huha2_2 ( cat ) values ( 1 )
> insert into huha2_2 ( cat ) values ( 2 )
> insert into huha2_2 ( cat ) values ( 3 )
> ... and so forth.
> The column "gimme" is there:
> $ v.info -c huha2
> Displaying column types/names for database connection of layer 1:
> INTEGER|cat
> INTEGER|gimme
> Why does v.to.db ignore it? I thought I could use any integer column
> for storing categories...
what if 'v.reclass column=gimmie' is done first. i.e. is it hard-coded
to "cat" or is it hard-coded to the category key?
Hamish
