[GRASS-dev] [bug #5175] (grass) v.to.db: 'option=cat' not updating
columns other than 'cat'
Maciek Sieczka via RT
grass-bugs at intevation.de
Sun Oct 1 07:48:58 EDT 2006
hamish_nospam at yahoo.com wrote (Sun, Oct 1 2006 08:34:45):
> is it hard-coded to "cat" or is it hard-coded to the category key?
Hamish,
Thanks for the hint. It is hard-coded to the category key it shows.
I have connected a table using column 'gimme' for key:
$ v.db.connect -p huha_rcl
Vector map <huha_rcl> is connected by:
layer <1> table <huha_rcl> in database
</home/grassdata/spearfish60/sieczka/dbf/> through driver <dbf> with key
<gimme>
and now v.to.db wants to populate the 'gimme' no matter what column I specify:
$v.to.db -s map=huha_rcl type=point option=cat column=cat
Updating database ...
insert into huha_rcl ( gimme ) values ( 1 )
insert into huha_rcl ( gimme ) values ( 2 )
insert into huha_rcl ( gimme ) values ( 3 )
Maciek
-------------------------------------------- Managed by Request Tracker
