[GRASS-dev] GIF -> PNG
    Glynn Clements
    glynn at gclements.plus.com
    Mon Oct  2 14:53:48 EDT 2006
Hamish wrote:
> with this set in ~/.grass.bashrc:
>   export GRASS_HTML_BROWSER=dillo
> it works fine from NVIZ, but the startup GUI defaults to using klunky
> old mozilla as .grass.bashrc hasn't been sourced yet(?).
You can always set it in your normal ~/.bash_profile etc.
> Also is there
> any way to get rid of or minimize the residual xterm window?
Yes; just don't use an xterm, i.e. change:
	exec -- $env(GISBASE)/etc/grass-xterm-wrapper -e $env(GRASS_HTML_BROWSER) \
	file://$env(GISBASE)/docs/html/helptext.html >@stdout 2>@stderr &;
to:
	exec -- $env(GRASS_HTML_BROWSER) \
I don't see why an xterm should be necessary. If you want to use
lynx/links, you can set GRASS_HTML_BROWSER to a script which starts
lynx/links in an xterm, e.g.:
	#!/bin/sh
	exec xterm -e lynx "$@"
