[GRASS-dev] v.clean tool=prune - 'thresh' interpreted wrong?
Maciej Sieczka
tutey at o2.pl
Mon Oct 2 15:10:05 EDT 2006
There is a line:
$ echo "L 4 1
10 10
20 10
30 10
40 10
1 1" | v.in.ascii -n out=line format=standard
So there are 4 vertices and the distance between each 2 following is
10. Then I don't understand why the:
$ v.clean input=line output=line_pruned type=line tool=prune
thresh=1
removes ALL the vertices!:
$ v.out.ascii line_pruned format=standard
ORGANIZATION:
DIGIT DATE:
DIGIT NAME: shoofi
MAP NAME:
MAP DATE: Mon Oct 2 20:51:52 2006
MAP SCALE: 1
OTHER INFO:
ZONE: 0
MAP THRESH: 0.000000
VERTI:
L 2 1
10 10
40 10 <- WHY ARE THE TWO OTHER GONE ???
1 1
I declared thresh=1, the distance between vertices is 10 - so none
should be removed, but all are! And the same happens with all the lower
thresholds until thresh=0.03.
v.clean man says: "prune: remove vertices in threshold". Maybe I don't
understand what the threshold means in this case?
Maciek
P.S.
Any clarification will be highly appreciated. I've been writing a
script that uses pruning and I would like to publish it, but this is
puzzling me bad and I don't know whether it's a bug or my mistake. Thanks.
