[GRASS-dev] [bug #5186] (grass) diglib compilation problem
(Solaris2.9/Sparc)
Request Tracker
grass-bugs at intevation.de
Tue Oct 3 07:47:34 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5186
Subject: diglib compilation problem (Solaris2.9/Sparc)
There is a problem with lib/vector/diglib:
the compiler complains about this with most files in this folder:
"/home/fysop/92/harkiisk/include/ogr_core.h", line 200: warning:
enumerator value overflows INT_MAX (2147483647)"
Which may be the reason that at the end of the compilation I get:
cd OBJ.sparc-sun-solaris2.9;
LD_LIBRARY_PATH=":/home/fysop/92/harkiisk/src/grass6/dist.sparc-sun-solaris2.9/lib"
./test; diff
+./test.tmp ../test.ok
ERROR in read/write portable long, byte_order = 1
Written: -2147483647
Read : 2147483649
Written: -123456789
Read : 4171510507
but the module exists.
[report inserted by MN]
-------------------------------------------- Managed by Request Tracker
