[GRASS-dev] Re: [GRASS-user] v.clean tool=prune - 'thresh'
interpreted wrong?
Markus Neteler
neteler at itc.it
Tue Oct 3 08:33:16 EDT 2006
On Tue, Oct 03, 2006 at 02:23:56PM +0200, Moritz Lennert wrote:
> Doesn't
> 20 5
> 30 7.5
> 40 10
> Define a straight line ? I would guess that the prune tool prunes all
> "unneccessary" nodes on a straight line, i.e. any node which is not
> necessary to define the line, and this whatever the threshold.
> The threshold only applies in cases of change of direction (i.e. angles).
> Just another example of the need for much more documentation for
> v.clean, including example diagrams like the one for the rmsa tool.
Fully agreed... but let me reiterate that a different pruning
algorithm might be the best solution (e.g. Douglas-Peucker which
is found as C code on the GMT site). The current one doesn't even work
in LatLong.
Markus
