[GRASS-dev] Re: [GRASS-user] [bug #2765] v.buffer bug??
Dylan Beaudette
dylan.beaudette at gmail.com
Tue Oct 3 18:43:29 EDT 2006
Thanks Hamish,
I have applied the patch, and run v.buffer on a sample data set, and all seems
to be well. however my sample data was a set of line segments: and not areas,
as was the case with Macieck.
Perhaps this test case is known.
Cheers,
Dylan
On Sunday 01 October 2006 18:23, Hamish wrote:
> Dylan Beaudette wrote:
> > > > http://intevation.de/rt/webrt?serial_num=2765
> > > Hi,
> > > I have a patch I think gets around the famous v.buffer bug
> > > (attached), please test.
> > will try it out on the latest CVS,
> > PS: pardon my stupidity, but how would i apply this patch (forgot!)
> cd /where/grass/is/
> patch -p0 < patch.diff
> cd lib/vector/Vlib/
> make
> or if that doesn't work and it's small patch like this one, just make
> the changes by hand.
> Hamish
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
