[GRASS-dev] auto-man page creation after KEYWORD support
Markus Neteler neteler at itc.it
Thu Oct 5 04:06:48 EDT 2006
On Thu, Oct 05, 2006 at 08:19:57PM +1300, Hamish wrote:
> CVS log for grass6/raster/r.le/r.le.setup/description.html
> Default branch: MAIN
> Revision 1.8, Wed Sep 27 15:00:04 2006 UTC (7 days, 16 hours ago) by
> markus
> Branch: MAIN
> CVS Tags: HEAD
> Changes since 1.7: +7 -1 lines
> Diff to previous 1.7
> DESCIPTION restored (otherwise the documentation system fails)
> Hi,
> http://grass.ibiblio.org/grass63/manuals/html63_user/raster.html
> now contains "KEYWORDS" as part of the module description for the
> interactive modules. (eg r.le.*)
> does the bit that wants "DESCIPTION" above need to know about "KEYWORDS"
> too?
The module  r.le.patch, r.le.pixel, r.le.trace are lacking
the definition of:
    module = G_define_module();
    module->keywords = _("...");
    module->description =  _("...");
This is causing the ugly output (also in 6.2).
Markus
