[GRASS-dev] Re: [Ffmpeg-devel] Problems with preC99 compilers
Glynn Clements
glynn at gclements.plus.com
Fri Oct 6 02:48:05 EDT 2006
Hamish wrote:
> > > > I was compiling recent GRASS GIS version but it failed on ffmpeg
> > > > includes due to one line comments. One line comments (//) where
> > > > introduced in C99, thus preC99 compilers do not understand them.
> > > All widely used compilers from the past several years understand
> > > them. Even the obsolete gcc versions from before any real C99
> > > support understood them.
> > > > gcc version 4.1.2 20060920 (prerelease)
> > > Supports not only // but most of the more complex features of C99
> > > too.
> > > > Error message:
> > > > gcc
> > > > -I/home/maris/soft/grass-6.2.0RC1/dist.i686-pc-linux-gnu/include
> > > > -g -ansi -Wall
> > > The -ansi switch explicitly sets the standard back to C89 and
> > > disables support for any features of current C and GNU extensions
> > > that were not present in C89. Remove that switch and it'll compile.
> The current state:
> grass63$ grep -rI '^//' * | grep -v terraflow
> swig/python/python_grass6.i://File : python_grass6.i
> swig/python/my_typemaps.i:// G_free_list($1);
> vector/v.edit/del.c:// Vect_delete_line(Map, id);
> vector/v.edit/del.c:// Vect_delete_line(Map, area);
> vector/v.edit/cat.c:// G_message(_("Reading vector: "));
> vector/v.edit/cat.c:// G_percent(line, nlines, 1);
> vector/v.edit/add.c:// ret = Vect_get_point_in_poly(line, &xc, &yc);
> vector/v.edit/main.c://static int error_routine(const char*msg, int fatal);
> vector/v.edit/main.c:// G_set_error_routine(error_routine);
> vector/v.edit/main.c:// Vect_set_open_level(2);
> vector/v.edit/main.c:// Vect_set_category_index_update ( &Map );
> vector/v.edit/main.c:// G_unset_error_routine();
> vector/v.drape/spearfish.pov://background { color SkyBlue }
IOW, it's just v.edit; the others aren't C files.
> (v.edit isn't built by default)
That would probably explain why no-one has noticed it before; people
do occasionally build with -ansi.
Fixed in CVS.
