[GRASS-dev] [bug #5176] (grass) v.in.ogr: segfault when a full path to dsn is missing
Maciek Sieczka via RT grass-bugs at intevation.de
Sat Oct 7 07:45:21 EDT 2006
rez at touchofmadness.com wrote (Thu, Oct 5 2006 05:35:57):
> Should be fixed in CVS.
Brad,
I'm sorry but it's not. Still exactly the same problem using today's CVS.
Here's a backtrace:
$ ulimit -c 3000
$ grass63
$ v.in.ogr dsn=force_lrconnect_cl_onlycat139
output=force_lrconnect_cl_onlycat139_import
layer=force_lrconnect_cl_onlycat139
(segfault)
$ gdb v.in.ogr core
(gdb) bt
#0  0x00010101 in ?? ()
#1  0xb7cb5c2f in OGRSpatialReference::Release ()
   from /usr/local/lib/libgdal.so.1
#2  0xb7cab4e7 in OGRGeometry::~OGRGeometry () from
#3  0xb7ca6810 in OGRCurve::~OGRCurve () from /usr/local/lib/libgdal.so.1
#4  0xb7ca6ad8 in OGRLineString::~OGRLineString ()
#5  0xb7caf6ff in OGRFeature::~OGRFeature () from
#6  0xb7caefa5 in OGR_F_Destroy () from /usr/local/lib/libgdal.so.1
#7  0x0804ccfc in main (argc=4, argv=0xbffcb044) at main.c:744
(gdb) q
Grass or GDAL issue? Using GDAL 1.3.2+CVS 2006-07-24.
Maciek
-------------------------------------------- Managed by Request Tracker
