[GRASS-dev] r.mapcalc and g.remove --v/q issues
Glynn Clements
glynn at gclements.plus.com
Mon Oct 9 06:28:05 EDT 2006
Martin Landa wrote:
> trying to cleanup g.remove module I have prepared the patch. Is it OK
> for you? Any comments welcomed...
Rather than hard-coding checks for specific entity types:
+ if (G_strcasecmp(list[n].alias, "rast") == 0 ) {
+ if ((mapset = G_find_cell2 (old, "")) == NULL) {
+ G_warning(_("Raster map <%s> not found"), old);
+ result = 1;
+ if (G_strcasecmp(list[n].alias, "rast3d") == 0 ) {
+ if ((mapset = G_find_grid3 (old, "")) == NULL) {
+ G_warning(_("Raster 3d map <%s> not found"), old);
+ result = 1;
I would add a flag which is initially cleared for each entity (map
etc) and set when an element is actually removed. A warning would be
generated if the flag is still clear when all of the elements for an
entity have been processed.
E.g.:
+ removed = 0;
for (i = 0; i < list[n].nelem; i++) {
switch (G_remove (list[n].element[i], old))
case -1:
- G_warning (" %-*s %s", len, list[n].desc[i],_("COULD NOT REMOVE"));
+ G_warning ("%s: %s", list[n].desc[i],_("couldn't be removed"));
result = 1;
break;
case 0:
- G_message (" %-*s %s", len, list[n].desc[i],_("MISSING"));
+ G_debug (1, "%s: %s", list[n].desc[i],_("missing"));
break;
case 1:
- G_message (" %-*s ", len, list[n].desc[i]);
+ G_debug (1, "%s: %s", list[n].desc[i],_("removed"));
+ removed = 1;
break;
+ if (!removed)
+ G_warning ("%s: %s", list[n].desc[i],_("nothing removed"));
