[GRASS-dev] adding 'desc' to dbf sql driver
Moritz Lennert
mlennert at club.worldonline.be
Mon Oct 9 07:50:45 EDT 2006
Daniel Calvelo wrote:
> Hi Moritz,
> Looks good to me. In the yac.y patch, you don't need to duplicate the
> code for ORDER BY NAME and ORDER BY NAME ASC.
How do I take care of the case where neither asc nor desc are given in
the sql ? This should default to asc, but this:
+y_order_asc:
+ NAME | NAME ASC {
sqpOrderColumn( $1, SORT_ASC ); }
does not work, i.e. results of 'order by' without asc are not sorted.
So how does this need to be formulated ?
> For cmp_row_desc, you
> could just return( - cmp_row_asc) with the same arguments. Glynn, a
> cursory look?
Did that and it seems to work.
> FYI, the text file in lib/db/sqlp/test/test allows for some testing of
> the parser. That may help you find any hidden bugs in the sqlp part of
> your patch.
I get
Input row: -->>INSERT INTO pok ( c1, c2,c3) VALUES ( 'abc', +32, +56.7 );
Input statement: -->>INSERT INTO pok ( c1, c2,c3) VALUES ( 'abc', +32,
+56.7 )<<--
Error: statement was not parsed successfully.
Don't know how this would be related to my changes.
(BTW
INSERT INTO pok ( c1, c2,c3) VALUES ( 'abc', -32, -56.7 );
does not cause any problems.)
If I remove the above insert statement and add:
SELECT c1,c3 FROM pok order by c1;
it runs perfectly.
However, when I insert
SELECT c1,c3 FROM pok order by c1 ASC;
or
SELECT c1,c3 FROM pok order by c1 DESC;
I get a segmentation fault:
Input row: -->>SELECT c1,c3 FROM pok order by c1 ASC;
Input statement: -->>SELECT c1,c3 FROM pok order by c1 ASC<<--
********** SQL PARSER RESULT **********
INPUT: SELECT c1,c3 FROM pok order by c1 ASC
COMMAND: SELECT
TABLE: pok
COLUMN 1: c1
COLUMN 2: c3
./test2: line 15: 32474 Done echo "SELECT c1,c3 FROM
pok where c3 <> 34 and c5 = 2.3;
INSERT INTO pok VALUES ( 'abc', 32, 56.7 );
INSERT INTO pok ( c1, c2,c3) VALUES ( 'abc', 32, 56.7 );
upDAte pok SET c2 = '5', c3 = 1 WHERE c1 = '1' AND c5 = 6;
delete FROM pok WHERE c1 = '1' and c2=3 AND c5 <= 4.35;
CREATE TABLE pok ( c1 INT, c2 VARCHAR (5), c3 DOUBLE );
DROP TABLE pok;
ALTER TABLE pok ADD COLUMN id int;
ALTER TABLE pok ADD popis varchar(10);
UPDATE pok SET c2 = NULL, c1=c2, c3=(-c3+12)/c1 where c1 NOT NULL;
update pok set c1=c2,c2=c1,c3=NULL where c1+2>1/cat+0.5 and not (c1=1 or
c2=2);" 32475 Segmentation fault | ./sqlptest
I'm a bit lost here. What is print.c used for ?
> You might also wish to update print.c to accomodate for
> asc/desc (it's a one-line change near the end).
Did that, but not sure if correctly. Should I check for the existance of
orderDir before using it, i.e. should it rather be
if ( sqlpStmt->command == SQLP_SELECT ) {
if ( sqlpStmt->orderDir )
fprintf( stderr, "ORDER BY: %s %s\n", sqlpStmt->orderCol,
sqlpStmt->orderDir );
} else {
fprintf( stderr, "ORDER BY: %s\n", sqlpStmt->orderCol );
or is this not necessary ?
> And of course, after testing, this has to be documented :)
Obviously... :-)
Moritz
