[GRASS-dev] r.li: new version and tests
Hamish
hamish_nospam at yahoo.com
Mon Oct 9 21:12:09 EDT 2006
Paolo Cavallini wrote:
> A new version of r.li (0.2.6) is available at the usual site:
> http://www.faunalia.it/download/r_li/
> A bug preventing floating points calculations has been discovered and
> fixed. First test on the comparison with r.le give very encouraging
> results: numeric differences between the two programs are *very*
> small, presumably due to rounding effects. A map of the differences is
> available: http://www.faunalia.it/download/r_li/shannon.png is the
> resulting map (Shannon index)
> http://www.faunalia.it/download/r_li/diff.png is the map of the
> differences. All the best.
Nice.
what's the difference in running times?
G63> time r.le.patch map=rastermap
etc
when will this be ready for 6.3-cvs? (if that's your intention)
what are the advantages over r.le?
Hamish
