[GRASS-dev] no v.digit in wingrass
Glynn Clements
glynn at gclements.plus.com
Tue Oct 10 00:23:59 EDT 2006
Moritz Lennert wrote:
> Am I right in assuming that v.digit cannot run in wingrass because of
> the current need for a monitor to be run which is not possible in MS Win ?
Correct.
> So the only current option for MS Win users is to use QGIS ?
Or Cygwin with X.
It might be possible to build XDRIVER for MinGW using --enable-w11; I
haven't tried.
