[GRASS-dev] v.kernel Vect_check_input_output_name
Radim Blazek
radim.blazek at gmail.com
Tue Oct 10 04:50:19 EDT 2006
On 10/10/06, Hamish <hamish_nospam at yahoo.com> wrote:
> Radim Blazek wrote:
> > v.kernel should not use Vect_check_input_output_name for output
> > because output is raster.
> output is both raster and vector,
> out_opt->description = _("output raster/vector map");
Yes, you are right, it should only be checked if net is used.
Radim
> and then there's this:
> if( !flag_q->answer ) {
> Vect_open_new (&Out, out_opt->answer, 0);
> Vect_hist_command ( &Out );
> Vect_write_line ( &Out, GV_LINE, SPoints, SCats );
> Vect_build (&Out, stderr);
> Vect_close (&Out);
> Hamish
