raster MASKs; was [GRASS-dev] interferring ovewrite flags
Tue Oct 10 21:52:00 EDT 2006
Glynn Clements wrote:
> As every module supports --o, the GUI should unconditionally add a
> checkbox for overwrite. It shouldn't expect the parser to tell it to
> do so.
--o is added to modules that can use it, ie. with gisprompt = "new,,"
r.out.* and d.* modules for example don't have it & it doesn't make
sense there.
g.module --html-description  adds it when needed
g.module --interface-description  apparently doesn't
g.module --tcltk  apparently doesn't
need to copy the logic from --html to --tcltk in lib/gis/parser.c
Hamish
