[GRASS-dev] vectors invisible if has layer2 but no layer1
Maciej Sieczka tutey at o2.pl
Wed Oct 11 13:47:03 EDT 2006
I have noticed that if I have a vector that has categories in layer 2
and no cats in layer 1, d.vect by default doesn't display any of the
features, unless I specify layer=2 explicitely.
Try this - create a vector 'map' without categories in any layer.
Display it - you see it, OK. Now add categories into layer 2 only:
v.category in=map out=map_addcat_l2 option=add layer=2
d.erase
d.vect map_addcat_l2
You see nothing. No good. Could that be fixed?
Maciek
