[GRASS-dev] [bug #5205] (grass) r.colors color=rules: few seconds
delay between each warning
Glynn Clements
glynn at gclements.plus.com
Thu Oct 12 12:51:23 EDT 2006
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=5205
> Subject: r.colors color=rules: few seconds delay between each warning
> If one makes a mistake in rules, resuming from each warning takes few sec.
> eg.
> $ r.colors map color=rules
> Data range is 0 to 5
> > [ENTER]
> WARNING: bad color specification
> [few seconds]
> WARNING: rule is not added
> [few seconds]
The delay is built into lib/gis/error.c; it should be removed, IMHO.
