[GRASS-dev] Re: [bug #4725] "nviz vol=raster3d" lockup
Mon Oct 16 02:13:14 EDT 2006
Hamish wrote:
> NVIZ 3D raster volume works ok if loaded with:
> nviz -q
> Panel->Raster volumes
> Add, etc.
> but locks up NVIZ while setting up the menus (panel->volumes).
that should be:
but locks up if NVIZ is started from the command line with
  nviz volume=raster_map3d
The freeze happens while setting up the menus (panel->volumes).
Hamish
