[GRASS-dev] making r.out.gdal region sensitive
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Oct 18 05:00:53 EDT 2006
Oops, the line endings on that patch got corrupted - please look at this
one instead.
On Wed, 18 Oct 2006, Jachym Cepicky wrote:
> hallo,
> On Tue, Oct 17, 2006 at 10:56:58PM +0100, Paul Kelly wrote:
>> Hello Jachym
>> In order for the behaviour of r.out.gdal to be consistent with other
>> r.out.* modules, I think it would be more appropriate for it to first
>> use
>> r.resample to resample the map according to the current region (this
>> is
>> what the other modules do) into a temporary raster map and then export
>> that.
> could you point me to some example? how to create temporary raster file?
> i tryed something, see this patch
> On Wed, Oct 18, 2006 at 09:03:54AM +0200, Maciej Sieczka wrote:
>> Please, but only as an option. We can't remove any current behavior
>> unless it's a bug.
>> In GRASS 7 region-sensitiveness in r.out.gdal should become the
>> default
>> however - for consistency with other r.out.* modules.
> i added -r flag for "region sensitive"
> jachym
> Jachym Cepicky
> e-mail: jachym.cepicky at centrum.cz
> URL: http://les-ejk.cz
> GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
> OFFICE:
> Department of Geoinformation Technologies
> Zemedelska 3
> 613 00, Brno
> Czech Republick
> e-mail: xcepicky at node.mendelu.cz
> URL:    http://mapserver.mendelu.cz
> Tel.:   +420 545 134 514
Index: r.out.gdal
RCS file: /grassrepository/grass6/scripts/r.out.gdal/r.out.gdal,v
retrieving revision 1.24
diff -u -r1.24 r.out.gdal
--- r.out.gdal	19 Aug 2006 12:52:24 -0000	1.24
+++ r.out.gdal	18 Oct 2006 08:07:59 -0000
@@ -22,6 +22,10 @@
 #%  key: l
 #%  description: list supported output formats
 #%END
+#%flag
+#%  key: r
+#%  description: region sensitive output
+#%END
 #%option
 #% key: input
 #% type: string
@@ -89,6 +93,7 @@
 OUTPUT="$GIS_OPT_OUTPUT"
 CREATEKEY="`echo "$GIS_OPT_CREATEOPT" | sed 's+,+ -co +g' | sed 's+^+-co +g'`"
 METAKEY="`echo "$GIS_OPT_METAOPT" | sed 's+,+ -mo +g' | sed 's+^+-mo +g'`"
+REGION=""
 if [ $GIS_FLAG_L -eq 1 ] ; then
   gdal_translate | grep ':' | grep -v 'Usage' | grep -v 'The following'
@@ -99,6 +104,15 @@
 #echo $INPUT $FORMAT $OUTPUT
 #echo $GDAL_INPUT_FORMATS
+# region sensitive output
+if [ $GIS_FLAG_R -eq 1 ] ; then
+    TEMPRASTER=r.out.gdal_${INPUT}_$$
+    r.resample input=$INPUT output=$TEMPRASTER
+    INPUT=$TEMPRASTER
+fi
 #fetch the input raster map
 eval `g.findfile element=cell file=$INPUT`
 if [ ! "$file" ] ; then
@@ -129,9 +143,14 @@
   unset METAKEY
 fi
 #do it
 CELLHD=`echo $file | sed 's+/cell/+/cellhd/+g'`
 echo "Writing format: $FORMAT"
 echo "Writing type:   $TYPE"
 gdal_translate -of $FORMAT -ot $TYPE $CREATEKEY $METAKEY $CELLHD $OUTPUT
+    g.remove $TEMPRASTER
+fi
