[GRASS-dev] making r.out.gdal region sensitive
Hamish
hamish_nospam at yahoo.com
Wed Oct 18 19:22:14 EDT 2006
> >> In order for the behaviour of r.out.gdal to be consistent with
> >> other r.out.* modules,
just a check re. region bounds & grid vs. pixel conventions, does a
full cycle result in the same exact data?
r.out.gdal -r in=orig_map format=[...] out=map.ext
r.in.gdal in=map.ext out=map2
r.resample in=orig_map out=orig_map.resamp
r.mapcalc diff="orig_map.resamp - map2"
r.univar diff
Hamish
