[GRASS-dev] [bug #5212] (grass) default color map range does
not cover full data
Hamish
hamish_nospam at yahoo.com
Wed Oct 18 19:37:18 EDT 2006
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=5212
> > Subject: default color map range does not cover full data
> This isn't an issue with colour tables per se, but with the range
> calculation. "r.info colorbug" says:
> $ r.info colorbug | fgrep Range
> | Range of data: min = 0.250000 max = 2400.750000
[less keystrokes: r.info -r]
> Looking at G_row_update_fp_range():
[Glynn fixes it]
I take it this also affected the g3d library & fixes any problems there?
lib/g3d/g3drange.c
Hamish
