[GRASS-dev] Creating location from file problem
Markus Neteler
neteler at itc.it
Fri Oct 20 04:46:23 EDT 2006
together with Helena I tried to create new location from a file,
it fails if a datum should be asked:
> 1. Create new location from a file -
> I put the file at:
> http://skagit.meas.ncsu.edu/~helena/grasswork/grassbookdat/gdc.zip
When selecting the SHAPE file, the procedure in
lib/init/file_option.tcl
calls g.proj. In this case, it wants to query the user for the
datum, but for that it has to be run in the xterm wrapper which
isn't the case yet.
I tried
diff -u -r1.5 file_option.tcl
--- file_option.tcl 19 Oct 2006 12:03:48 -0000 1.5
+++ file_option.tcl 20 Oct 2006 08:45:28 -0000
@@ -114,8 +114,7 @@
if {[file exists $filepath]== 1} {
if {[file exists $thelocation ]==0} {
destroy .fileloc;
- exec -- g.proj -c georef=$filepath location=$fileLocation >@stdout 2>@stderr;
- destroy .fileloc
+ exec -- $env(GISBASE)/etc/grass-xterm-wrapper -e g.proj -c georef=$filepath location=$fileLocation;
DialogGen .wrnDlg [G_msg "WARNING: restart GRASS please"] warning \
[G_msg "WARNING: Please restart GRASS in order find the created location in the list (closing it for you now)"] \
0 OK;
but the xterm window only flashes, then closes.
How to do it right?
Markus
