[GRASS-dev] d.vect -a shows only some elements
Martin Landa
landa.martin at gmail.com
Sat Oct 21 03:49:20 EDT 2006
2006/10/21, Moritz Lennert <mlennert at club.worldonline.be>:
[snip]
> > you are right (if I understand well), adding
> > db_CatValArray_sort (&cvarr_rgb);
> > should solve the problem. I wonder why db_select_CatValArray sorts
> > cvarr->value by category number only for data type int or double...
> > (?), see
> > 00300 if ( type == DB_C_TYPE_INT )
> > 00301 qsort( (void *) cvarr->value, nrows, sizeof(dbCatVal),
> > cmpcat);
> > 00302 else if ( type == DB_C_TYPE_DOUBLE )
> > 00303 qsort( (void *) cvarr->value, nrows, sizeof(dbCatVal),
> > cmpcat);
> Applying below patch directly to db_select_CatValArray solves the problem
> for me, but I don't know if this might cause other problems, even though I
> doubt it.
> Any ideas ?
> Moritz
> Index: lib/db/dbmi_client/select.c
> RCS file: /grassrepository/grass6/lib/db/dbmi_client/select.c,v
> retrieving revision 1.8
> diff -u -r1.8 select.c
> --- lib/db/dbmi_client/select.c 14 Jul 2006 16:41:22 -0000 1.8
> +++ lib/db/dbmi_client/select.c 20 Oct 2006 23:22:26 -0000
> @@ -297,10 +297,7 @@
> db_close_cursor(&cursor);
> db_free_string ( &stmt );
> - if ( type == DB_C_TYPE_INT )
> - qsort( (void *) cvarr->value, nrows, sizeof(dbCatVal), cmpcat);
> - else if ( type == DB_C_TYPE_DOUBLE )
> + db_CatValArray_sort ( cvarr );
> return (nrows);
in this case the array is sorted twice for datatype DB_C_TYPE_INT and
DB_C_TYPE_DOUBLE, I suggest
RCS file: /home/grass/grassrepository/grass6/lib/db/dbmi_client/select.c,v
+++ lib/db/dbmi_client/select.c 21 Oct 2006 07:43:35 -0000
@@ -297,9 +297,8 @@
+ if ( type == DB_C_TYPE_INT || type == DB_C_TYPE_DOUBLE ||
+ type == DB_C_TYPE_STRING )
return (nrows);
Not sure if you need to check "type" here (what about DB_C_TYPE_DATETIME)??
Best, Martin
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
