[GRASS-dev] verbosity and G_done_msg
Sun Oct 22 21:23:30 EDT 2006
Jachym Cepicky wrote:
> I'm not shure, if I should leave G_done_msg("") at end of some
> modules.
> User actually does not care, that some module is done - he allready
> knows it.
not necessarily! Even if the user returns to the GRASS> prompt.
Working....
GRASS>
did it finish or crash? (we crash a lot, unfortunately)
The user probably doesn't know about "echo $?" tests.
> What do you think: should I remove G_done_msg("") funcitions from the
> end of each main() function of each module or should we add this
> function to end of each module?
> I would remove it, IMHO it has no sence to report end of the program,
> when it ends.
I believe it should be present. It uses G_message() so --quiet or
GRASS_VERBOSE<2 will get rid of it.
- It is not always clear when a GUI module has finished.
The module gui from the command line (without gis.m) has no "running
man".. the output messages just stop arriving.
- For long running modules it is very nice to have some sort of
reassurance that the module has finished successfully.
I would not add it to all modules automatically, e.g. for d.rast and
g.remove it is pointless.
Hamish
