[Fwd: Re: [GRASS-dev] Re: 6.2 epsg version]
Maciej Sieczka tutey at o2.pl
Mon Oct 23 01:58:42 EDT 2006
Hi Markus,
Forwarding message from Roger Lott of EPSG. Now Frank can sync GDAL
with new EPSG database and then GRASS can use corrected GDAL's .csv files.
Temat: Re: [GRASS-dev] Re: 6.2 epsg version
Data: Sat, 21 Oct 2006 22:32:19 +0100
Nadawca: Roger Lott (EPSG) <epsg.rl at btinternet.com>
Adresat: Maciej Sieczka <tutey at o2.pl>,	GRASS developers list
<grass-dev at grass.itc.it>,	Frank Warmerdam <warmerdam at pobox.com>
Odniesienia: <20061019095503.335ce179.hamish_nospam at yahoo.com>
<20061018215940.GA12808 at bartok.itc.it> <45373461.7040200 at o2.pl>
<20061019132418.GA17485 at bartok.itc.it> <453780EF.9020802 at o2.pl>
I'm unclear why the subject of this email train is 6.2 epsg version - I
presume it is a typo for 6.11.2.
Version 6.11.2 of the EPSG dataset has been sent to our web master for
public release. He is usually pretty quick at doing what is necessary
and it
would not surprise me if the release is available some time on Monday.
The only change to v6.11.1 is the reinstatement of the 4 CRSs 2172-2175
for
Poland. We have run two independent checks which confirmed that these seem
to be the only records that went missing, although we have been unable to
trace the cause - I would guess human error!
v6.11.1 corrects errors in v6.11 for Carolina and Hong Kong CRSs. It also
adds additional new data, as summarised in the release note. v6.11 has
been
withdrawn and should not be used.
Regards,
Roger Lott
