[GRASS-dev] r.mapcalc addition
Hamish
hamish_nospam at yahoo.com
Mon Oct 23 19:15:11 EDT 2006
Glynn Clements wrote:
> Joel Pitt wrote:
> > It'd be great if someone could commit the attached addition to
> > r.mapcalc
> > It basically allows one to specify the seed for random number
> > generation by adding a new function "erand(a,b,s)" which takes a and
> > b as the lower and upper limit, and s is a seed that is used to
> > initiate the pseudo random number generator.
> > This is useful in modelling and simulation so that particular
> > replicates can be rerun exactly.
> > If it needs any extra work let me know and I'll make the changes.
> I consider this to be the wrong approach. At a minimum, setting the
> seed should be decoupled from the generation of random numbers;
> there's no reason to have what is essentially another copy of
> f_rand().
> Also, it's debatable whether an r.mapcalc function is the correct
> mechanism for setting an operating parameter. An environment variable
> might be more suitable.
> Finally, even if f_erand() was the correct interface, having it call
> f_rand() once the seed has been set is preferable to including a clone
> of f_rand() in the body of f_erand().
what if r.mapcalc's rand(a,b) fn had an optional third argument? ie the
seed. rand(a,b) would work as it currently does, but rand(a,b,seed)
would be available if you wanted it.
Hamish
