[GRASS-dev] r.out.gdal rewritten
Tue Oct 24 17:34:50 EDT 2006
Martin Landa wrote:
> it is great, thanks a lot for this!! There is small patch (not
> important changes). I think it should be added to CVS as r.out.gdal2
> (e.g.)
Add it as raster/r.out.gdal (the existing script is in the scripts
directory). You can name the executable r.out.gdal2 while it's being
tested then change it to r.out.gdal when it's stable, but we don't
want to have to rename the directory later.
