[GRASS-dev] Integration of a new Tcl/tk script
Michael Barton michael.barton at asu.edu
Fri Oct 27 00:46:05 EDT 2006
Thierry,
I'm happy to work with you on this, but am out of town and subsequently tied
up into next week.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Thierry Gonon <thierrygonon at mac.com>
> Date: Thu, 26 Oct 2006 21:04:43 +0300
> To: <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] Integration of a new Tcl/tk script
> Hi everybody,
> I've finally succeeded in creating my script to help the creation of SQL
> queries.
> Now, my problem is the good integration of this script in GRASS... When I run
> it (I add a Xtns submenu, "Build a query"), it starts a new GRASS_WISH, so
> when it ends (after having done his job !), it produce in GRASS GIS Manager
> the following error :
> can't read "opt(0,pgm_name)": no such variable
>     while executing
> "set pgm_name $opt($dlg,pgm_name)"
>     (procedure "dialog_set_command" line 3)
>     invoked from within
> "dialog_set_command $dlg $cmd"
>     (procedure "run_ui" line 14)
>     invoked from within
> "run_ui $cmd"
>     (procedure "execute" line 3)
>     invoked from within
> "execute db_q.tcl"
>     (menu invoke)
> And when I click "OK" on the error window, it create a "dialog 0" window in
> GRASS.
> (my script is in the /scripts folder)
> What do I have to do ???
> When this thing will be solved, I will be able to distribute this script...
> but I don't know how to produce the Makefile !!! so I will need your help once
> again ! (I will work soon on the description file...)
> Thank you very much !
> Thierry Gonon
