[GRASS-dev] [bug #5243] (grass) d.vect: better random color
generation
Request Tracker
grass-bugs at intevation.de
Sun Oct 29 02:12:06 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5243
[wish]
currently "d.vect -c" random colors is limited to 16 colors, which do
not rotate between calls. (you get the same colors every time, d.redraw
doesn't help if you don't like the results)
see display/d.vect/plot.h for current candidates.
I suggest using random color code from lib/gis/color_rand.c to do a
better job. It seems to work pretty well.
or if that won't work (too many cats to store RGB values) start with
random seed and calculate R,G,B values by some mathematical function
which will give the same answers for those 3 variables within the module
run.
thanks,
Hamish
--- Headers Follow ---
>From hamish_nospam at yahoo.com Sun Oct 29 08:12:05 2006
Return-Path: <hamish_nospam at yahoo.com>
Delivered-To: grass-bugs at lists.intevation.de
Received: from kolab.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id D9B871006AB
for <grass-bugs at lists.intevation.de>; Sun, 29 Oct 2006 08:12:05 +0100 (CET)
Received: from localhost (localhost.localdomain [127.0.0.1])
by kolab.intevation.de (Postfix) with ESMTP id BFDC41B1A17
by kolab.intevation.de (Postfix) with ESMTP id A690B1AFCC3
Received: from mailhub1.otago.ac.nz (mailhub1.otago.ac.nz [139.80.64.218])
by kolab.intevation.de (Postfix) with ESMTP id B66381AD41A
for <grass-bugs at intevation.de>; Sun, 29 Oct 2006 08:10:31 +0100 (CET)
Received: from galadriel.otago.ac.nz (galadriel.otago.ac.nz [139.80.64.213])
by mailhub1.otago.ac.nz (8.13.6/8.13.6) with ESMTP id k9T7AQP8003694
for <grass-bugs at intevation.de>; Sun, 29 Oct 2006 20:10:26 +1300
Received: from taihua.otago.ac.nz ([139.80.35.27] helo=taihua)
by galadriel.otago.ac.nz with smtp (Exim 4.50)
id 1Ge4oH-0003m1-R6
for grass-bugs at intevation.de; Sun, 29 Oct 2006 20:10:21 +1300
Date: Sun, 29 Oct 2006 20:10:26 +1300
To: grass-bugs at intevation.de
Subject: d.vect: better random color generation
Message-Id: <20061029201026.72a37491.hamish_nospam at yahoo.com>
X-Mailer: Sylpheed version 1.0.4 (GTK+ 1.2.10; i386-pc-linux-gnu)
X-Face: M<EoB)"*Z~u!,vFhXmw}R_KbdBta*P_=T|rbBL'e1/CQ9;/1g\BU3&!=y8ria$2Uk!HT&BB
8i?|X_+7~1jsy}F~g$2va%3fV`*=L(*cem[@3\yg,G, at rg6/QMJ
Mime-Version: 1.0
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
X-Virus-Scanned: by amavisd-new at intevation.de
X-Spam-Status: No, hits=1.7 tagged_above=-999 required=3 tests=[BAYES_20=-1,
FORGED_YAHOO_RCVD=2.7]
X-Spam-Level: *
-------------------------------------------- Managed by Request Tracker
