[GRASS-dev] r.watershed updates
Hamish
hamish_nospam at yahoo.com
Mon Oct 30 00:04:35 EST 2006
Helena Mitasova wrote:
> > Accumulation map: number of cells that drain through each cell
> > | Range of data: min = -16269552 max = 8562412
> > (way negative? way postive?) bulk of data is 0->2000 though, so
> > after setting color rules the map looks ok.
> Did you read the manual?
not well enough apparently :) now I have & understand what it means
Hamish
