[GRASS-dev] elevation.dted from spearfish
Markus Neteler neteler at itc.it
Mon Oct 30 06:24:21 EST 2006
Hamish,
are you sure that you have the latest Spearfish package?
http://grass.itc.it/sampledata/spearfish60_history.txt
----- Spearfish 6.0 - 0.2 :
26 Jul 2006 [M. Sieczka]
- removed outdated file PERMANENT/TODO (consulted with the author,
  Helena Mitasova)
- uncomented 'e-w resol' and 'n-s resol' in
  PERMANENT/cellhd/elevation.dted (fixes bug #4879)
We are at
http://grass.itc.it/sampledata/spearfish_grass60data-0.3.tar.gz
now :-)
Cheers
Markus
Hamish wrote on 10/30/2006 11:18 AM:
> Hi,
> elevation.dted at PERMANENT in spearfish has this problem:
>  (slightly old spearfish60..)
> G63> g.region rast=elevation.dted
> ERROR: Invalid region: Illegal n-s3 resolution value
> G63> cat spearfish60/PERMANENT/cellhd/elevation.dted
> proj:       1
> zone:       13
> north:      4927700
> south:      4913700
> east:       609000
> west:       590000
> cols:       190
> rows:       140
> #e-w resol:  100
> #n-s resol:  100
> format:     0
> compressed: 0
> what's with the commented res?
> G63> r.info elevation.dted -s
> nsres=100
> ewres=100
> looks ok.
> I got this error in gis.m when trying to zoom to selected map:
> Error:can't read "parts(n)": no such variable
>     while executing
> "MapCanvas::zoom_new $mon $parts(n) $parts(s) $parts(e)  $parts(w) $parts(nsres) $parts(ewres)"
>     (procedure "MapCanvas::zoom_gregion" line 11)
>     invoked from within
> "MapCanvas::zoom_gregion $mon [list "rast=$map"]"
>     (procedure "MapCanvas::zoom_map" line 45)
>     invoked from within
> "MapCanvas::zoom_map $mon"
>     invoked from within
> ".mapcan(1).mf.topf.tb0.mapzoom.zm invoke active"
>     ("uplevel" body line 1)
>     invoked from within
> "uplevel #0 [list $w invoke active]"
>     (procedure "tkMenuInvoke" line 47)
>     invoked from within
> "tkMenuInvoke .mapcan(1).mf.topf.tb0.mapzoom.zm 1
>     (command bound to event)
> Hamish
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
