[GRASS-dev] Re: [bug #5218] (grass) wingrass: creating new
location from startup screen with projection values fails
Glynn Clements
glynn at gclements.plus.com
Mon Oct 30 15:40:13 EST 2006
Huidae Cho wrote:
> > >>And Huidae provides:
> > >>fftw-2.1.5-1 gdal-1.3.2-1 geos-2.2.3-1 proj-4.4.9-1 sqlite-3.3.6-1
> > >>xdr-4.0-1
> > >>from http://geni.ath.cx/grass/
> > >>Isn't that enough ?
> > >If he provides usable packages (compiled libraries and headers), then
> > >we should use those. However, I get a "forbidden" error for the above
> > >URL, and I couldn't find individual packages from the main page.
> Directory browsing is forbidden, but access to an individual file is
> allowed. I'm following what the web server admin decided to do.
Could you add links to the individual files somewhere?
In its current state, the native Windows version is arguably more
useful to developers wishing to help with the port than people who
actually want to use it, so an environment where you can compile GRASS
is more important than one where you can use it.
For that, a monolithic installer isn't necessarily the best approach.
