[GRASS-dev] r.distance problem: in our out?
Jachym Cepicky
jachym.cepicky at centrum.cz
Tue Oct 31 11:03:00 EST 2006
hallo,
Dylan tested and found no error. Patch commited, r.distance has -o flag
for taking care on overlapping rasters
jachym
On Tue, Oct 10, 2006 at 03:33:56PM +0200, Jachym Cepicky wrote:
> hallo,
> On Wed, Oct 04, 2006 at 01:38:25PM +0200, Markus Neteler wrote:
> > Hi,
> > for an application I have to calculate the distance between
> > raster "objects". While this generally works, I have found
> > that r.distance happily calculates the distance even if
> > one object is within the other (say, raster pixel over
> > raster polygon in second map). I would need an indication
> > somehow that we are *in* (to ignore the distance in this
> > case).
> i did not found any G_is_null(raster_map_name,x,y) or similar function.
> is there something like this?
> thank you
> jachym
> one cell from mypixel is "surrounded"
> > Spearfish example:
> > g.region -dp
> > # extract field #25:
> > r.mapcalc "myarea=if(fields == 25, 1,null())"
> > # this archsite falls into field 25:
> > v.extract archsites out=mypixel list=9
> > v.to.rast mypixel out=mypixel use=val val=1
> > r.distance mypixel,myarea
> > # -> reports two distant points
> > # zoom:
> > g.region n=4926990 s=4925856 w=599850 e=601376 align=myarea
> > d.mon x0
> > d.rast myarea
> > d.vect mypixel col=blue
> > # visualize distance (d.graph give sometimes random output!):
> > r.distance mypixel,myarea | awk -F: '{print "move",$4,$5,"\ndraw",$6,$7}' | d.graph -m
> > # generate points from distance for easier verification:
> > r.distance mypixel,myarea | awk -F: '{print $4,"|",$5,"\n",$6,"|",$7}' | sed 's+ ++g' | v.in.ascii out=distance
> > d.vect distance col=yellow
> > # cleanup:
> > g.remove rast=myarea,mypixel
> > g.remove vect=mypixel,distance
> > Problem: There is no indication that we are *within* the area. Maybe a flag is
> > needed to optionally suppress the result in this case?
> > Better ideas?
> > Second problem: The result seems to be underestimated by half a cell
> > since not the cell edge is taken from the raster polygon boundary
> > but the cell center.
> > Appreciating help,
> > Markus
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
> Jachym Cepicky
> e-mail: jachym.cepicky at centrum.cz
> URL: http://les-ejk.cz
> GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
> OFFICE:
> Department of Geoinformation Technologies
> Zemedelska 3
> 613 00, Brno
> Czech Republick
> e-mail: xcepicky at node.mendelu.cz
> URL: http://mapserver.mendelu.cz
> Tel.: +420 545 134 514
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20061031/5375c318/attachment.bin
