[GRASS-dev] r.out.png giving files a .png extension
Paul Kelly
paul-grass at stjohnspoint.co.uk
Tue Oct 31 13:10:17 EST 2006
I prepared a patch for r.out.png (see below) that ensures the output file
always has a ".png" extension (if the user supplied output file name
already contains .png that is OK - if not r.out.png will now add it). I
will commit it in a few days unless anyone gives a good reason why someone
might need r.out.png to create PNG files that don't have a .png extension.
Paul
Index: r.out.png.c
RCS file:
/home/grass/grassrepository/grass6/raster/r.out.png/r.out.png.c,v
retrieving revision 2.5
diff -u -r2.5 r.out.png.c
--- r.out.png.c 28 Oct 2006 20:33:33 -0000 2.5
+++ r.out.png.c 31 Oct 2006 18:04:21 -0000
@@ -50,7 +50,7 @@
struct GModule *module;
struct Option *rast, *png_file;
struct Flag *bequiet;
- char *cellmap, *map, *p, ofile[1000];
+ char *cellmap, *map, *p, *basename = NULL, *ofile;
char rastermap[1024];
unsigned char *set, *ored, *ogrn, *oblu;
CELL *cell_buf;
@@ -141,7 +141,7 @@
if (strcmp(png_file->answer, "<rasterfilename>.png")) {
if (strcmp(png_file->answer, "-"))
- strncpy(ofile, png_file->answer, 1000 * sizeof(char));
+ basename = G_store(png_file->answer);
else
do_stdout = 1;
@@ -152,8 +152,15 @@
if (p != map)
*p = '\0';
- strncpy(ofile, map, 995 * sizeof(char));
- strcat(ofile, ".png");
+ basename = G_store(map);
+ if(basename)
+ G_basename(basename, "png");
+ ofile = G_malloc(strlen(basename) + 5);
+ sprintf(ofile, "%s.png", basename);
+ G_free(basename);
/*G_get_set_window (&w); *//* 10/99 MN: check for current region */
@@ -187,6 +194,8 @@
fp = stdout;
else if (NULL == (fp = fopen(ofile, "w")))
G_fatal_error("Not able to open file for [%s]", ofile);
+ else
+ G_free(ofile);
png_ptr = png_create_write_struct(PNG_LIBPNG_VER_STRING,
