[GRASS-dev] gis.m patch
Huidae Cho
grass4u at gmail.com
Sat Sep 2 11:54:25 EDT 2006
Find attached the patch.
Huidae
On Sat, Sep 02, 2006 at 11:39:58AM +0200, Maciej Sieczka wrote:
> Huidae Cho wrote:
> > Hi,
> > I've patched gis.m so that it can run on Windows natively with the help
> > of direct rendering. PDCurses lets the user to start in text mode, but
> > since there are no monitors available, gis.m is the only option for now.
> > http://geni.ath.cx/grass/native_wingrass.png shows gis.m running on
> > MS-Windows (not Cygwin).
> Oh shoot, great!
> Can you re-send the patch as an attachment?
> Michael,
> Aply it?
> Maciek
Index: gui/tcltk/gis.m/gm.tcl
RCS file: /grassrepository/grass6/gui/tcltk/gis.m/gm.tcl,v
retrieving revision 1.25
diff -u -r1.25 gm.tcl
--- gui/tcltk/gis.m/gm.tcl 24 Aug 2006 18:04:57 -0000 1.25
+++ gui/tcltk/gis.m/gm.tcl 2 Sep 2006 06:00:41 -0000
@@ -69,6 +69,12 @@
set execom "spawn"
+if {[info exists env(MSYSCON)]} {
+ set mingw "1"
+ set mingw "0"
#fetch GRASS Version number:
set fp [open $env(GISBASE)/etc/VERSIONNUMBER r]
set GRASSVERSION [read -nonewline $fp]
@@ -188,7 +194,13 @@
# Determine if an element already exists
proc Gm::element_exists {elem name} {
- set failure [catch {exec [list "|g.findfile" "element=$elem" "file=$name"] >& /dev/null}]
+ global mingw
+ if { $mingw == "1" } {
+ set failure [catch {exec [list "|g.findfile" "element=$elem" "file=$name"] >& nul}]
+ set failure [catch {exec [list "|g.findfile" "element=$elem" "file=$name"] >& /dev/null}]
return [expr {! $failure}]
Index: gui/tcltk/gis.m/gmmenu.tcl
RCS file: /grassrepository/grass6/gui/tcltk/gis.m/gmmenu.tcl,v
retrieving revision 1.15
diff -u -r1.15 gmmenu.tcl
--- gui/tcltk/gis.m/gmmenu.tcl 20 Jul 2006 17:43:19 -0000 1.15
+++ gui/tcltk/gis.m/gmmenu.tcl 2 Sep 2006 06:00:41 -0000
@@ -19,6 +19,7 @@
global mon
global filename
global env
+global mingw
# Put this at the top of the file menu.
set GuiMenu::Menu_File_Top [subst {
@@ -48,10 +49,20 @@
lappend descmenu all
lappend descmenu options
lappend descmenu $tmenu
-lappend descmenu [subst {
- {command {[G_msg "GRASS help"]} {} "g.manual" {} -command { exec g.manual -i > /dev/null & } }
- {command {[G_msg "GIS Manager &help"]} {} {[G_msg "GIS Manager help"]} {} -command { exec g.manual gis.m > /dev/null & } }
- {command {[G_msg "About &GRASS"]} {} {[G_msg "About GRASS"]} {} -command { source $env(GISBASE)/etc/gm/grassabout.tcl} }
- {command {[G_msg "About &System"]} {} {[G_msg "About System"]} {} -command { exec $env(GRASS_WISH) $env(GISBASE)/etc/gm/tksys.tcl --tcltk & }}
+# MinGW
+if { $mingw == "1" } {
+ lappend descmenu [subst {
+ {command {[G_msg "GRASS help"]} {} "g.manual" {} -command { exec g.manual -i >& nul } }
+ {command {[G_msg "GIS Manager &help"]} {} {[G_msg "GIS Manager help"]} {} -command { exec g.manual gis.m >& nul } }
+ {command {[G_msg "About &GRASS"]} {} {[G_msg "About GRASS"]} {} -command { source $env(GISBASE)/etc/gm/grassabout.tcl} }
+ {command {[G_msg "About &System"]} {} {[G_msg "About System"]} {} -command { exec $env(GRASS_WISH) $env(GISBASE)/etc/gm/tksys.tcl --tcltk & }}
+ {command {[G_msg "GRASS help"]} {} "g.manual" {} -command { exec g.manual -i > /dev/null & } }
+ {command {[G_msg "GIS Manager &help"]} {} {[G_msg "GIS Manager help"]} {} -command { exec g.manual gis.m > /dev/null & } }
Index: gui/tcltk/gis.m/runandoutput.tcl
RCS file: /grassrepository/grass6/gui/tcltk/gis.m/runandoutput.tcl,v
retrieving revision 1.12
diff -u -r1.12 runandoutput.tcl
--- gui/tcltk/gis.m/runandoutput.tcl 27 Aug 2006 21:19:26 -0000 1.12
+++ gui/tcltk/gis.m/runandoutput.tcl 2 Sep 2006 06:00:41 -0000
@@ -169,11 +169,17 @@
proc run {cmd args} {
+ global mingw
# This and runcmd are being used to run command in the background
# These used to go to stdout and stderr
# but we don't want to pollute that console.
# eval exec -- $cmd $args >@ stdout 2>@ stderr
- eval [list exec -- $cmd] $args >& /dev/null
+ eval [list exec -- $cmd] $args >& nul
+ eval [list exec -- $cmd] $args >& /dev/null
Index: lib/gtcltk/gronsole.tcl
RCS file: /grassrepository/grass6/lib/gtcltk/gronsole.tcl,v
retrieving revision 1.6
diff -u -r1.6 gronsole.tcl
--- lib/gtcltk/gronsole.tcl 27 Aug 2006 21:19:26 -0000 1.6
+++ lib/gtcltk/gronsole.tcl 2 Sep 2006 06:00:43 -0000
@@ -425,10 +425,16 @@
proc Gronsole::execout {path cmd ci execcmd} {
global env
+ global mingw
set mark cmdinsert$ci
# Actually run the program
- set cmd [concat | $cmd 2>@ stdout]
+ set cmd [concat | $cmd]
+ set cmd [concat | $cmd 2>@ stdout]
set message_env [exec g.gisenv get=GRASS_MESSAGE_FORMAT]
set env(GRASS_MESSAGE_FORMAT) gui
Index: lib/gtcltk/options.tcl
RCS file: /grassrepository/grass6/lib/gtcltk/options.tcl,v
retrieving revision 1.7
diff -u -r1.7 options.tcl
--- lib/gtcltk/options.tcl 19 May 2006 21:19:16 -0000 1.7
+++ lib/gtcltk/options.tcl 2 Sep 2006 06:00:43 -0000
@@ -98,3 +98,9 @@
if { $osxaqua == "1"} {
set keycontrol "Command"
+ set mingw "1"
+} else {
+ set mingw "0"
