[GRASS-dev] gis.m patch
Sat Sep 2 13:56:00 EDT 2006
Huidae Cho wrote:
> I've patched gis.m so that it can run on Windows natively with the help
> of direct rendering.  PDCurses lets the user to start in text mode, but
> since there are no monitors available, gis.m is the only option for now.
> +	if { $mingw == "1" } {
> +		set failure [catch {exec [list "|g.findfile" "element=$elem" "file=$name"] >& nul}]
> +		set failure [catch {exec [list "|g.findfile" "element=$elem" "file=$name"] >& /dev/null}]
Rather than duplicate entire commands, I would be inclined to create a
global variable, e.g.:
	set devnull [expr {$mingw == 1 ? "nul" : "/dev/null"}]
then use:
	global devnull
	set failure [catch {exec "|g.findfile" "element=$elem" "file=$name" >& $devnull}]
[Note that the original exec command was broken.]
