[GRASS-dev] v.in.ogr broken (\w shp)
Hamish
hamish_nospam at yahoo.com
Sun Sep 3 03:59:33 EDT 2006
Brad Douglas wrote:
> Is there an easy fix for this? I'm trying to import a shapefile and
> I'm not terribly familiar with this part of the GRASS architecture.
> GRASS 6.3.cvs (hamilton):~/hamilton > v.in.ogr dsn=. output=roads
> layer=17
> Projection of input dataset and current location appear to match.
> Proceeding with import...
> Layer: 17
> DBMI-DBF driver error:
> Column 'ADMIN_CLAS' already exists (duplicate name)
> Cannot create table.
> Error in db_execute_immediate()
> ERROR: Cannot create table: create table roads (cat integer, PREFIX
> varchar
> ( 2 ), NAME varchar ( 30 ), TYPE varchar ( 4 ), SUFFIX varchar
> ( 2
> ), FCC varchar ( 3 ), FIPS varchar ( 11 ), ID integer,
> FULL_NAME varchar ( 40 ), ADMIN_CLAS varchar ( 40 ), CATEGORY
> integer, ST_CNTY_FI varchar ( 11 ), RD_CLASS varchar ( 4 ),
> RTE_NUM1
> varchar
> ( 4 ), RTE_NUM2 varchar ( 4 ), ADMIN_CLAS integer, AREA double
> precision, LEN double precision)
DBF limits column names to 10 chars; you end up with "ADMIN_CLAS" twice
in the above list. Either change DB column names or user the v.in.ogr
cnames= option to rename columns to something unique. (hint, cut & paste
above list with modification). Maybe changing DB to SQLite or something
helps too?
Hamish
