[GRASS-dev] v.in.ogr broken (\w shp)
Brad Douglas
rez at touchofmadness.com
Fri Sep 1 12:01:53 EDT 2006
Is there an easy fix for this? I'm trying to import a shapefile and I'm
not terribly familiar with this part of the GRASS architecture.
GRASS 6.3.cvs (hamilton):~/hamilton > v.in.ogr dsn=. output=roads
layer=17
Projection of input dataset and current location appear to match.
Proceeding with import...
Layer: 17
DBMI-DBF driver error:
Column 'ADMIN_CLAS' already exists (duplicate name)
Cannot create table.
Error in db_execute_immediate()
ERROR: Cannot create table: create table roads (cat integer, PREFIX
varchar
( 2 ), NAME varchar ( 30 ), TYPE varchar ( 4 ), SUFFIX varchar
( 2
), FCC varchar ( 3 ), FIPS varchar ( 11 ), ID integer, FULL_NAME
varchar ( 40 ), ADMIN_CLAS varchar ( 40 ), CATEGORY integer,
ST_CNTY_FI varchar ( 11 ), RD_CLASS varchar ( 4 ), RTE_NUM1
varchar
( 4 ), RTE_NUM2 varchar ( 4 ), ADMIN_CLAS integer, AREA double
precision, LEN double precision)
Brad Douglas <rez touchofmadness com> KB8UYR
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
